Old 03-24-2018, 05:52 AM   #1
Smallblock454
Dashboard sound system modification
Hello,
i have the 986 sound package (HAES speakers) with CD-R 23. My speakers were OK, but i wanted to improve the sound quality. And don't wanted to invest too much money.
First i analyzed the electronic circuit. Just a simple electrolytic cap with 4.7 uF. Hm, that would mean an incomplete -6 dB crossover only for the tweeter at around 8 Khz. Crap.
Next i've tested the cap capacity. One cap was within specs. The other way off. No wonder you can't hear them, when the crossover frequency is way above 8 Khz with a bad cap.
So i did some tests with different caps and coils. In the end i decided to use 6.3 uF MKP caps and 0,22 mH coils. To my ears that sounds much better, because the mid frequencies (higher voice frequency) are damped a bit. Still use the fader to reduce power to the dash speakers and give door speakers a little more power.
This is a comparison to the BOSE dash speakers. I preferred the HAES ones, because the are 10 cm in diameter while the BOSE ones are only 8 cm in diameter and didn't had enough lower mid power in this configuration. Tweeters seems to be the same:
This is the beta product (changed caps from 5.6 to 6.8 uF - see above). Didn't do a photo of the final product, but looks the same:
If you want to copy the idea, take care that the caps are enough on the inside, so you get the loudspeakers with the casing in the dash without problems.
