Old 03-22-2018, 04:40 AM   #26
JFP in PA
Originally Posted by rexcramer View Post
Here is a topic I have never seen discussed. Has anybody used a 'flush chemical' prior to refilling? I am going to guess the OEM fluid group hasn't. What about the Prestone faithful? Prestone makes a 'flush and cleaner.' Back in the day when the earth was flat, I always used a flush on my cast iron blocks before replacing the anti-freeze.
Most threads/videos speak to flushing once or twice with distilled only.
Unless you want to replace your water pump, I would suggest against it. We only use flush chemicals in the case of an intermix, other wise just flush it with clear water.
