Old 03-21-2018, 07:52 PM   #1
jaykay
jaykay's Avatar
Novel approach my man.....well done. I hope it works well. Do you plan to use sealant on the joints....if you are not pulling it apart too often something like RTV might work....just slice it open a remove the bead when the time comes.
then again if intake air temperatures don't go up then maybe all is okay.
To get more room for this kind of stuff. I wonder if there is a good procedure for slightly lowering the engine and trans about 3 inches without disconnecting a myriad of items. You can rotate the front an engine down but by how much without damaging the trans mounts
986 00S
