Old 03-21-2018, 07:55 AM   #1
JFP in PA
Originally Posted by jandr95 View Post
I'd leave it alone altogether but I thought I should remove some fluid before I push in and replace the front pads. Plus I kinda wanted to know the current color so I could maybe buy a contrasting color. Then I'll know when I've pushed the old stuff out.
Sounds like I just have to be more aggressive with the damn thing.
Thanks for all the replies.
Then removing the strainer it totally unnecessary. There is absolutely no need to remove any fluid from the reservoir before changing the front pads. And if you are going to use something like the Motive pressure flushing system, again there is no need to remove the strainer; the Motive system uses positive displacement to push all of the old fluid out ahead of the new stuff. And even if you stay with the same color fluid, there is an obvious change in appearance when the clean shows up at the bleeder.
