			Sounds like you're on track.  Did you remove a couple of screws on each side along with the three bolts?  The screws can be hard to see down there as they are black.
 If you have it all loose, get a buddy to help lift it out.  You do move it back a bit and tilt the rear upward.  Also, IIRC, I had the top in the down position (completely) when removing.
