Softtop remove/install Clarification please
So, can someone who recently removed and installed a softtop with frame help me? It's loose and ready to come out and the instructions I read from a search says to move entire frame rearward a couple inches and lift out. But when I try that method the inner most frame hole comes into contact with the rollbar hoop. Im trying to install a glass window frame 03/04 to a 02 which should be a simple swap frame to frame. And I should not have to remove the clamshell.
