Old 03-19-2018, 06:20 AM   #5
Doug427
I'm thinking the easiest thing to do is to just replace the oil cooler and of course the associated o-rings and go from there. I just bought the car so the thought that some knucklehead prior owner added oil to the coolant tank by accident occurred to me. I sort of doubt that however because in the little use I have given the car so far, it marks it's parking spot with a fairly good sized oil spot almost each time. If my theory that it's coming from the coolant tank is correct, that means that a fresh supply of oil is getting dumped into the tank each time I use the car. I'm thinking and hoping that BirdDog and I are correct.
I found a new Behr oil cooler on line for only $112.00, so it's fairly cost efficient to just do the swap and multiple flushes, and see how it goes from there. The refreshing of this car was/is coming along really, really well, so this new development is sort of a bummer. I'm hoping that it turns out to just a bump in the road.
Doug427 is offline   Reply With Quote
