Old 03-15-2018, 03:28 PM   #1
particlewave
Originally Posted by Cunningr View Post
I would make the IMS a priority, mine was done already when I bought it. Not sure of the failure rates, but it may not give warning. I supposecthere is a way to have it checked. When you do the clutch consider a lighter flywheel. Good luck!
Replacing the IMS bearing on a '98 is not really necessary. There's a 99% chance it will not fail.
Stay away from lightweight flywheels unless you plan to have the crank/flywheel balanced. The 986 does not have a harmonic balancer. Crank balance is achieved with the dual mass flywheel, so installing a lightweight flywheel could result in vibrations and even broken crankshafts.
