Old 03-15-2018, 08:09 AM   #10
911monty
911monty's Avatar
Originally Posted by M4tus View Post
Thank you to all.
@911monty
Ok I will pull out both lights and compare the gaps. I am afraiding there is something broken inside. Is it able to disasemble litronic reflector, (projector unit) and buy any spare parts or complete new unit?
If the reflector pivot has popped off it is extremely tedious to fix. It would be much easier to do by removing the lens. I did mine through the opening on the backside but it is not easy.
edit. You do not need to pull the lights to check. Just look at the gaps from the front of the car. Also if yours has the little white leveling tab on the outer side compare them.
