Old 03-15-2018, 07:21 AM   #11
Starter986
1998 Boxster Silver/Red
I have an inquiry...
98 Boxster. Tip.
Soon I'll be replacing the thermostat and water pump. OP listed a parts list:
1 900-123-144-30 Crush Washer/Sealing Ring for Coolant Drain Plug (10 X 14 X 1 mm), Boxster/Boxster S (1997-04)
1 996-106-222-17 Water Hose to Water Pump (3-Way Hose), Boxster/Boxster S w/Manual Trans. (1997-04) (Purple Arrow)
1 996-106-501-07 Water Hose to Water Flange at Oil Pump Housing (Large Hose), Boxster/Boxster S (1997-04) (Orange Arrow)
1 996-106-502-06 Water Hose to Water Flange (Large Hose), 986 Boxster/Boxster S (1997-04) (Green Arrow)
1 996-106-212-11 Water Hose
1 999-512-609-09 Hose Clamp 32 x 12
3 999-512-589-09 Hose Clamp 25 x 12
1 999-512-606-09 Hose Clamp 29 x 12
2 999-512-594-09 Hose Clamp 53 x 12
2 999-512-668-09 Hose Clamp 49 x 12
The hose with 3 arms would be 4 in my case. Is this a comprehensive list? Anything else?
I've seen the PP photo with the hoses and such. Is there a reason why one wouldn't want to replace the radiator hoses closer to the front of the car, at the radiators? What would be recommendation on those?
Thank you.
1998 Porsche Boxster
