Old 03-14-2018, 07:51 AM   #1
speedyspaghetti
Originally Posted by Deserion View Post
Are you noticing any grinding when in motion? Kind of sounds like a failing wheel bearing. When you move the wheel side to side, are you able to get an assistant to see if there is any component motion? Does the front-right display this or just the front-left?
Only front left - the most noticeable thing is that sometimes when I'm making a sharp turn at low speeds - pulling out of parking spot or something - it almost sounds like the wheel stumbles / judders / scrapes? It's hard to explain. I don't really get much rotational noise though when at highway speeds.
speedyspaghetti is offline   Reply With Quote
