Old 03-12-2018, 01:31 PM   #505
geraintthomas
geraintthomas's Avatar
And voila, dials replaced!
The newer dot-matrix display gives a lot more information now, even without the extra stalks! Seatbelt, dimmer amount, key in ignition, temperature, etc.
I'm going to fit the extra stalk, but I'm waiting until a 4-stalk one appears as I'll get that so that I'd have cruise control too. With these newer dials, cruise control is built in, so they just need wiring in from the stalk and enabling. Pointless buying the 3-stalk one as I'd just have to swap it again when that time comes. They're rarer than hens teeth though.
Mileage correction is happening Wednesday - £80 to correct it back to the ECU mileage.
Nice having the new display though
In the meantime, I've taken out the faces to my old dials because I'm going to scan them in.
I know I said I wouldn't do the face upgrade, BUT there's a company in America (whitefaces.net) that do faces that slip over the needles. They also take custom requests, so I'm going to see if they can make mine. They have Boxster ones already but not of the 'S' variant. I was thinking of making some but put a slit at the bottom as I'm not risking removing the needles again, but that wouldn't work for the fuel and temperature gauges. Will need a think.
I had a look in my old projector lenses too, and found out why they started to dim.
Here's the reflective bowl:
And here's the inside:
It's just coated silver. You can see it peeling and burnt off completely! Obviously these are cheap £15 projectors, the same as the ones I've just put in. My new ones will eventually go the same way, so that'll be the time I invest in Morimoto projectors.
That's it for now
Porsche Boxster S Type 986
Bi-xenon Headlight Upgrade | 987 S 18" Anthracite Alloys | Android Head Unit | 5000k 55w HID's | 5000k Cree DRL's | 5000k Cree number plate lights | Cree LED Indicators | One-touch roof operation | Bypass exhaust pipes | Parking sensors | Ambient footwell lighting
geraintthomas is offline   Reply With Quote
