I placed the rings on recently on my2000. It makes a big difference on the appearance of the cluster...definitely better. I agree they are expensive and I couldn't find an alternative. I got mine at NRauto.com. Make sure you are careful with the superglue. I used as little as necessary when putting the rings on, just a drop in each of the 4 compass positions (n, s, e, w). That is plenty. I left the cluster on and did pretty well. Just be careful because the superglue will ruin the clear plastic on the guages. One more thing...dry fit the rings several times. It isn't as intuitive as one would think on how they fit. At least on mine, there wasn't any labeling that said top/bottom.
