Thread: Key troubles
Old 03-09-2018, 03:13 PM   #3
JFP in PA
Originally Posted by rexcramer View Post
The fob has/needs a transponder in it. Mine look like a glass pill. The car has to be programmed to read each pills corresponding number. If the number is not in the cars memory, it will not start. Open up the fob and see if it is in there. If it is, then you need to take it to the dealer and or a higher end indy to get it programmed. If it isn't, you need to buy a transponder/fob. I believe you can get that from keys-in-the-post also. Either way, you probably need to have the car programmed for another key.
Welcome to tribe.
That will not work. The key and transponder came with a very long IPAS code tag, which is the data that has to be entered into the system for the car to recognize the key. No IPAS code, no programing. There is no known way to recover that IPAS code from the transponder itself. If you don't have the original tag, you are out of luck.
Time for new keys and dealer programing, bring a large bag of cash......
