Old 03-08-2018, 08:10 PM   #3
78F350
Motorist & Coffee Drinker
78F350's Avatar
Originally Posted by Tweetdriver63 View Post
... the source of the water was a clogged drain. Seems this is a pretty common issue. Unfortunately, I didn't know about it until it was too late. I've cleared that up now, ...
Also consider getting a waterproof box for the immobilizer and making a small drain hole in the floor under the seat.
I'm looking into the possibilities. One is ECU Doctors, which runs about...
ECU Doctors has done good work for some forum members and is actually on the forum from time to time. Qmulus has done repairs on these and may cost less than the other options if he has time.
Am I right that buying a used one on ebay, or elsewhere, isn't really worth the risk?
There are some reliable eBay sellers that I trust. QualityPorscheParts is one of them.
Here on the forum classified section you can often buy a good set.
Itsnotanova (Woody) may have one: Parting out a whole lot of Boxsters
I have three spares from 2000 to 2002, one of which is in the classified section. All of mine only have one key.
I have repaired two flood salvaged Boxsters and both of them have a Immobilizer+DME+key fob from eBay. They work fine. The issue that may come up is that if you need a dealer to service your car, the DME will not have the correct VIN and other associated information. Not a big concern for me personally.
If you do buy a replacement set used, make sure that it matches the model of your car: Correct year range (DME version), Tiptronic or manual, Base or S, Same part number on the M535 box. Bonus points for more than one key and key fobs that are fully tested and guaranteed to work for remote locking/unlocking. You do NOT need a new key blade or ignition tumbler; you can just use your current key blade in the replacement fob(s).
