Old 03-07-2018, 07:42 PM   #4
AZ986S
AZ986S's Avatar
Light will go out when you replace the bad sensor. I melted a sensor coming down the hill into turn 10a at Road Atlanta and my brake wear light came on, got my heart rate up...
If you pull the brake pad wear sensor end out, you will probably see that one of them is melted into a blob, and that is probably the bad one, and is 99.999% one of the fronts.
I don't run any sensors anymore, I clipped about 1" from the end that connects to the wheel carrier, stripped the two wires, twisted them together and insulated them, and I just check my pads visually. Since I have the wheels off all the time due to track work and brake bleeding, it works for me
I've actually got an extra sensor I can send you if you PM me your address. IF I can find it... It was only $5 or so from R O C K A U T O . C O M.
What Steve said. I've jumpered mine since it became an annoyance for me.
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
