Old 03-05-2018, 05:52 PM   #5
AZ986S
AZ986S's Avatar
Your lines are excellent and you did a good job of hitting the apexes. Hope your next track day is drier.
Thanks Husker!
PCA DE this weekend at AMP and then Chuckwalla the next with Speed Ventures. Not anticipating any moisture
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
