refurbished injectors now car wont run
The cleaning fluid shouldn’t be left in the injectors too long - if they’d been put back in the car immediately after cleaning then they’d have been ok. They will be fine, but the injector guy will need to ‘unstick’ them - unless you want to try tapping them with the side of a screwdriver. That’s never worked for me, but it has for other mechanics that I used to work with.
The workshop that I used to work in would keep cleaned, used injectors in stock so that we could do a quick changeover and get the injector cleaning guy to do them in batches (cheaper). We learned the downside pretty quickly and the injector guy started adding a few drops of valve seat saver to each injector after the clean (which was a hassle for him so he had to start charging us the full price again).
No one’s fault really, although your mechanic has learned a lesson that it would have been good for you if he’d already learned it in the past.
2001 Boxster S, TipTronic in Seal Grey aka "The Imp"
2001 TE50, ESS in (now) Grigio Titanio Matallizzato aka "The Golden child"
