Old 03-05-2018, 12:06 PM   #8
Quadcammer
Originally Posted by Stiles13 View Post
So, does it release pressure into the AOS? I'm assuming the pressure is low since it is a fairly delicate plastic hose?
I believe the hoses will be subject to either vacuum or pressure, depending on situation.
Under throttle if you have some blowby, you will pressurize these tubes. The vent valve this therefore intended to vent that. Typically though, the hoses should be under vac.
