I don't know if i'm measuring something different to you. Is the middle of the diff output flange the same distance to the bellhousing as on the Boxster 5 speed? If it's shorter that gearbox probably won't be suitable, if it's further it'll be fine. I'm offering up a 2.7t at the moment with the gearbox spacer and a boxster 5 speed, it's tight on driveshaft clearance.
