Old 03-03-2018, 05:37 AM   #19
roboxster
Roboxster
To early to say anything about the sound.. these speakers are stiff and before they are played in, they will not give good sound, so do not get worried if it sounds bad at first.
I do believe that it will be good in the end.. but the car is fighting me every step of the way..
I am placing two of the amps on the frunk floor and one in the original location..
Plan on having a false floor bottom with a polycarbonate cutout in the middle.
This because of the fact that I want to use the space for luggage, and I want to keep the spare wheel.
Regarding the subwoofers, the enclosure is ca 32l when everything is gutted, so I will make a new bottom and mount the subs facing up, and I will also close up the ports so its airtight. And divide the enclosure inside.
That will probably give ca 14l for each subwoofer and manufacturer recommends 14.2l
The subs (Pioneer TS-SW2002D2) Require 67mm install depth and the inclosure will be ca 100mm so I can mount them ca 20mm deep to get them flush so maybe they can be used when the top is down.
roboxster is offline   Reply With Quote
