Old 03-01-2018, 04:56 PM   #13
Quadcammer
DIY thread!! How easy was it, any tricky gotchas?
Not even necessary. Its dead simple. suck or drain the fluid from the MC, remove the two hard lines and the push in clutch line. pull off reservoir (friction fit), and then two bolts. reverse to install, then bleed. piece of cake
does it mess w your heel/toe?
Its much better actually as I felt the pedal travel was too long for me to heel and toe well (i use the ball of my foot on the brake and side of my foot on the gas), which makes it harder with a pedal height mismatch. less useful if you actually use your heel and toe.
