Old 03-01-2018, 01:08 PM   #10
MN 986
MN 986's Avatar
Originally Posted by njbray View Post
I ended up putting on a 2004 glass window top and frame. You get a big window that works with the included frame and is easy to swap over and you still have good engine access.
If you can get one for around $1000 - basically same price as new top and labor to install.
The aftermarket glass tops sometimes look a bit weird to me and it is quite a job to install.
The best thing about any glass window is ease of use - no getting out to chop - use in any weather, etc.
This is one of the best mods I have done (04 top/frame on my 02) as far as ease of putting the top down in cold Minnesota Spring and Fall weather. Pretty simple swap. Highly recommended if you can find one!
MN 986 is offline   Reply With Quote
