Old 03-01-2018, 11:59 AM   #11
MWS
I mentioned this before, but I would again strongly suggest looking into replacing the front Bose. The reason I am suggesting this again is with the amount of work you are going to do, the front is where you will see the most improvement/bang for your buck (if you will). The staging in the Boxster heavily favors the fronts and replacement of all others with higher quality will still leave you with a flat sound (severely deadened mids and especially highs). You know the old saying..."no highs, no lows...must be Bose." I'm sure you know this, but low frequencies (long wavelengths) require "static" air for transmission and the moment the top is down, that air is gone leaving you with the remaining higher frequencies (mids and especially highs) combined with the fact that these frequencies can and will "bounce" off of the windshield only leads only to the conclusion the dominant sound should be provided by the best (or best possible) divers, and to be blunt, Bose are not those.
In any event, best wishes.
