Old 03-01-2018, 08:21 AM   #11
titaniumdave
Originally Posted by B6T View Post
Hey Dave,
Otherwise the crank sensor may not read and you'll be chasing no-start issues for weeks and probably end-up pushing the car off a cliff.
Yes, I just stuffed the whole part in the hole for a place keeper. I do not have the clutch worked out yet, the Valeo 2.7/4.2L is close but I need a 3mm spacer behind the flywheel to get the starter ring in the correct location AND the whole set up seems to be too close to the throw out bearing even with the motor/trans spacer ring. This gets worse with the 3mm spacer so the solution may be to make the flywheel thinner by 5-8mm depending on how it all measures. An easy but time consuming job on the mill. Keeps the tone ring in the correct position as well as dropping 2-3LB. off a very heavy clutch and makes it so I can swap discs and pressure plates in future rebuilds with off the shelf parts.
Once the clutch is worked out, then the depth of the sensor will be obvious. Looks like you are correct about not needing the spacer, I agree.
titaniumdave is offline   Reply With Quote
