Originally Posted by titaniumdave
More progress, modified the 987 trans to accept the crank position sensor for the Audi V8.
Hey Dave,
That metal piece under the crank angle sensor is actually a spacer. It is used depending on whether you have an auto engine or manual engine. I can't remember which is which, but if memory serves I believe I had to remove it when I swapped an automatic 2.7t into my manual B6 A4.
Otherwise the crank sensor may not read and you'll be chasing no-start issues for weeks and probably end-up pushing the car off a cliff.
