Old 02-27-2018, 07:47 PM   #3
Qmulus
inveniam viam aut faciam
Pull the oil fill cap and see if the noise goes away. If it does, you may have a torn diaphragm on the AOS, that will create a lot of vacuum in the crankcase, sometimes to the point that it pulls in air past the rear main seal causing the squealing noise. I had that happen on an Audi years ago. It sounded terrible, but was an easy fix.
The tip off to me is that the noise changes when you give it a bit of throttle. Under that condition, there is less vacuum in the intake, and therefore less being transferred to the crankcase through the AOS diaphragm.
Qmulus is offline   Reply With Quote
