Old 02-27-2018, 04:45 PM   #1
thom4782
thom4782's Avatar
Cam deviations should be between -6/+6. One of yours is outside the range and likely due to a worn variocam pad. At some point, you'll get a check engine light when the deviation becomes higher.
Actual angles look ok, I forget at what RPMs the variocams kick in, but 3000 rpms is in the range.
