Old 02-26-2018, 08:23 PM   #3
The Radium King
The Radium King's Avatar
vacuum-actuated valves tied to the vacuum system on the engine and activated by the same type switch that triggers the vacuum-actuated flap in the resonance tube in the intake. also uses the same electronic trigger signal from the dme, so the flaps open and bypass a portion of the muffler at 3000 or so rpm.
