Old 02-26-2018, 06:05 PM   #2
Boxstard
Have you considered drying down everything... and running a water hose around suspect areas to identify where is the leak?
Could one of the drain hoses have a leak... down where you can't see?
I can but before I do I want to know which drain holes may be suspect. Those under the clamshell are out, I guess boots from the spoiler bars into the trunk floor may be suspect but where are other drain holes that may be potentially lead to leakage into trunk?
