Old 02-26-2018, 11:40 AM   #1
Starter986
1998 Boxster Silver/Red
Originally Posted by Boxstard View Post
Thanks, I know those drain locations, but they seem not relevant to rear trunk leakage... if those drains under the clamshell were clogged (which I routinely clean), water could have been entered from front wall of the trunk where was dry.... most soaked area was in the back in right corner.
Also it does not list two drains in the trunk floor from the spoiler mounts or drains around the taillight mentioned, which I’m curious now.
Have you considered drying down everything... and running a water hose around suspect areas to identify where is the leak?
Could one of the drain hoses have a leak... down where you can't see?
1998 Porsche Boxster
