Old 02-25-2018, 02:37 PM   #3
thom4782
thom4782's Avatar
Thanks...I've bookmarked the link and made some progress.
If I select actual camshaft angles for both or either bank, monitor for a period, and then go to option and export, I see the values. So that's good.
What I want to do next is activate bank 1's variocam and see what effect it has on the bank 1actual angles. Here's where I run into a wall. It seems if I activate the variocam that it turns off actual angles monitoring. After my laptop recharges, I'll try activating bank 1 and then selecting the appropriate active value to monitor. I'm concerned that when I do this, it will stop the activation.
To sum up, I want to activate and monitor at the same time and record the result in a log or Excel file.
