Old 02-25-2018, 12:26 PM   #12
NewArt
Artist, 986S tinkerer
NewArt's Avatar
From TRK:
"they look pretty much as you should expect pre-tune. your rkats are idle trims and in %; around 2.5% each side which is high as expected but within the 4% spec. they are positive which means the ecu is adding fuel as expected.
your fra values are around 1.3; more than the 1.2 that i’d predicted but close enough for the cocktail napkin math that i’d done. again, they are positive which means adding fuel as expected and, very close to the 1.32 spec which triggers a cel.
so, i think you are good; science wins another one."
Thanks to The Radium King!
