Update: First, thanks for all the advice everyone. I took it to my shop and had the guy do a full on check all over the vehicle. As I expected, spark plugs need replacing along with the boots and seals. On top of that my cam covers are leaking, my oil separator hose is leaking (causing the air leak), and my oil pan is leaking. Other than that the motor mounts will probably need replacing within the next 10k. A little worse than I hoped for but a little better than I anticipated. I should be able to do the oil pan and spark plugs but I'll take it in for the cam covers and oil separator hose. All in all Im hoping itll be less than 2k but well see.
