Old 02-23-2018, 05:30 PM   #1
Bruce
Window drop question...again - passenger side
Late last fall I noticed the passenger side window was not dropping low enough to clear the top and open the door without the window catching on the top. I've been through a TON of websites and forums and still don't have a clear answer on where to turn next.
Both windows function with the console switch(es), up/down and one touch. Passenger side window does drop when I get ready to open the top. I can lower both windows with the key in the driver side door.
So far I've replaced the door handle microswitch...no help. I've disconnected the battery and reset the windows...nope. I even tried the 'cable tie' trick...nothing.
Spoke with my Indie guy and he suspects it may be a programming/learning thing.
Is it possible the window may need to be adjusted? Sometimes my wife will forget to WAIT that extra second for the window to drop.
Many thanks!
Bruce
2003 Boxster S - Artic Silver Metallic
Standard Black Leather, PSM
LT Alloy Carrera Wheels
37000 miles
Bruce is offline   Reply With Quote
