Old 02-21-2018, 01:26 PM   #10
robdelorenzo
I am looking at this job in the very near future.
I cannot determine what ball joint removal tool is the best one to use if one wants to not damage the ball joints on the coffin arms? The Harbor Freight one sounded good, but I cannot tell for sure if it needs grinding out or not. It also appears that the pickle fork will kill the ball joint boots. Also, can I replace only the outer tie rods since the ball joints are worn or will the TRW outer part not fit on the OEM inner arm? Thanks.
robdelorenzo is offline   Reply With Quote
