System is sealed so you shouldn't lose coolant.
Do you get condensation on trunk lid after driving?
Blinking light low is low. When I got condensation I may have had to add coolant periodically but never lost so much as to get blinking coolant low.
Condensation could be cap leak, purge valve leak or expansion tank crack leak
Then there is everything else associated with the cooling system that could leak.
As mentioned, a pressure test may reveal issue
Seal Grey
