I'm in the process of finishing up switching out an 02 engine (base) into my 01 (base) and the "while I have it out" costs DO add up. Just normal stuff like coolant hoses, plugs & tubes, water pump, serpentine belt, engine mount, spin on oil filter fitting, & UDP. And oil, coolant/distilled water, hose clamps, filters, and auto trans oil, gasket, and filter. Then, of course, I had to switch one of the v-cam solenoids from the old engine to the replacement--sheared wires. Once it's back on the road, I'm thinking that a water pump and an engine mount will become part of the 60,000 service. Doesn't pay to wait for things to break.
As much hardwater calcium carbonate as I found in the old engine, I've already started to save for a set of radiators.
On both of the engines, the water pumps showed no sign of failure.
Still, it seems strange to recycle a "perfectly good" water pump. They are inexpensive enough to replace and throw away, tho.
Oh, and I just bought $600+ in floor paint and have to rent a grinder for the concrete floor in my carport. Brake cleaner works great for getting up oil drips.
2001 Boxster
2007 Toyota Highlander
