Originally Posted by thstone
- Failing MAF
- Intake system air leak
- Low fuel pressure
- Low fuel volume
- Bad fuel injector(s)
- AOS failing
- Oil filler cap leaking or oil fill tube cracked and leaking
I'm aware of the symptoms - it's not fuel as it's fine under load, it's not the MAF as I've tested it, it's not the oil cap as the engine stalls when removing it.
Porsche Boxster S Type 986
Bi-xenon Headlight Upgrade | 987 S 18" Anthracite Alloys | Android Head Unit | 5000k 55w HID's | 5000k Cree DRL's | 5000k Cree number plate lights | Cree LED Indicators | One-touch roof operation | Bypass exhaust pipes | Parking sensors | Ambient footwell lighting
