Old 02-20-2018, 06:41 PM   #3
TrumpyAl
You will need 15mm on the rear to bring them out to stock. Fronts are fine. Any thing that you add on to that is a matter of taste/purpose, for instance 25mm rear and 10mm front, etc.
Does “bring them out to stock” mean the stock track (ie outside edge), or the stock offset. As these wheels are so much wider than stock, the two can’t both be true.
2001 Boxster S, TipTronic in Seal Grey aka "The Imp"
2001 TE50, ESS in (now) Grigio Titanio Matallizzato aka "The Golden child"
TrumpyAl is offline   Reply With Quote
