Old 02-20-2018, 05:49 AM   #12
Boxstard
When you're judging how quick your boxster is warming up, are you judging by how quick you start feeling heat? If that's the case then the foam inside the venting system might have gone bad. My wife's car has that problem and it takes awhile for it to heat up inside the cabin. Luckily that's a problem easy to live with in south Texas
Good point, my warm-up time reported before is with perfectly working heater after fixing up holed blend doors. Without heater at work, I’m sure the engine warms up quicker. I feel heat within a few minutes after cold start in winter Michigan. It warmed up overnight and 45F this morning, and warm-up time was noticeably shorter on my usual commute, probably in 6-7 min with heater on.
