Old 02-19-2018, 09:44 AM   #1
Lapister
Those 2 codes are referencing both banks 1,2 lean condition. Hissing does sound to be most likely vacuum leak after the maf. Did you check the hoses between the T and plenum? You are most likely introducing unmetered air thru a leak
Lapister is offline   Reply With Quote
