I had the same problem. I replaced the door latch mechanism on my 97 Boxster (very expensive as only a '97 will fit). It did not cure the problem. When I pull on either the inside or outside handle and open the door the interior lights go on but when I let go of either handle the window pops back up. I know the micro switches are working on both handles and the latch switch is working because the interior lights come on. I have also replaced the window regulator. Any Ideas would be appreciated.
