Old 02-14-2018, 12:32 PM   #1
Josephjochoa
I have an 02 Boxster S tiptronic. I cracked the lower AOS breather hose as well when installing new AOS. . It was brittle from heat and age. How did you get the new lower hose on? I have a new one but can’t even snake it in on the drivers side. Once one side is in how would you get in the other? Did you remove everything on top including the plenum? I’ve removed both cross tubes but still can’t get it in. Has anyone replaced this breather line with something more flexible like heat shielded rubber or silicone hose?
Josephjochoa is offline   Reply With Quote
