Old 02-13-2018, 07:55 AM   #9
Brian in Tucson
Originally Posted by baumnutde View Post
Question, has anyone ever heard a shop say that a loose camshaft can be tig welded to the sprocket to fix a loose camshaft
What year and model, and engine are we discussing.
I have a core engine which will be going to the recycler soon. I could make you a deal on cam & sprocket if you needed it. Engine is a 01, 2.7. It was kind of a mess leaking oil and had been run quite hot. But the cams don't look worse for wear, and the engine only has 74,500 miles on it.
2001 Boxster
2007 Toyota Highlander
