Old 02-12-2018, 03:34 PM   #8
seningen
seningen's Avatar
Originally Posted by baumnutde View Post
Question, has anyone ever heard a shop say that a loose camshaft can be tig welded to the sprocket to fix a loose camshaft
Are they talking about the bolts that hold the camshaft to the timing gear in the oil scavenge pumps. During assembly they lock the cam shaft to the chain sprocket,
but this is to set the timing AND it is friction held. If its not right, sounds like something else went wrong.
Without more information, it will be vary hard to help you. Otherwise its just speculation.
However -- it really sounds like your local indy is not Boxster knowledgeable.
Mike
Drivers: '15 Panamera Hybrid (wife's), ' 01 996 GT2, 00 Boxster S, '96 993 Çab/Tip (wife's)
Race Cars: '75 911 RSR Replica & '99 Spec Boxster
mike@lonestarrpm.com
seningen is offline   Reply With Quote
