Old 02-12-2018, 11:54 AM   #8
husker boxster
husker boxster's Avatar
Kirk is correct - 05 was a transition yr for IMS in the Boxster and 911. They went from a single row Gen II version to a larger single row Gen III bearing. The Gen II can be replaced, the Gen III cannot w/o a lot of work. The Gen II fails at approx. 8-10% rate while the Gen III fails at approx. 1%.
Unless you have a build date on extreme either end of the model yr (late 04 for Gen II or June / July 05 for Gen III), there's no way to know for sure which version you have until you drop the trans.
1989 928 S4 5 spd - black
