Old 02-10-2018, 08:20 AM   #1
78F350
Motorist & Coffee Drinker
78F350's Avatar
Disassemble instrument cluster (2001)
Initially posted to help someone replace broken levers, but may be useful to others:
The early clusters, 1997 - 1999 (?) are a little different inside. 2004 was pretty much the same.
Start by removing the cluster from the car. The Pelican Parts article, 101 Projects book are good for that:
https://www.pelicanparts.com/techarticles/Boxster_Tech/90-ELEC-996_Cluster/90-ELEC-996_Cluster.htm
Use extra care removing the connectors from the rear of the cluster. They can be very brittle. It may help to look in through the windshield as you unplug them.
Once the cluster is out, see these pictures for instructions:
