I have no experience with Porsche transmission, but I do with BMW 5 speed motorcycle ones. Read everything you can before you start. On the bimmer trans, there are shims that have to be measured and put in to preload the gear shafts. Too loose and the trans will be sloppier than normal (they are sloppy!) too tight and the trans will not turn.
This should be interesting. What happened to your old trannie? Why don't you have it rebuilt (or rebuild it yourself?) Keep us in the loop, and good luck.
2001 Boxster
2007 Toyota Highlander
