Old 02-10-2018, 04:59 AM   #26
Troutman
So this is one of those jobs that i go to now and again...it's not much fun.
I tried different methods of welding to the broken studs but nothing worked. I put the welder away and I will be drilling them all out.
So far i've done 2 ..yes just 2. I work up in 0.5mm increments from 3mm to 6.8mm then use a tapered M8 tap re thread the hole. They seem good and the bolts that came out screw in really well.
The drill guides I had made up work really well for getting the first 3mm hole done.
Here you can see.
I'm just going to take my time with this..no rush.
Troutman is offline   Reply With Quote
